Results 1 to 10 of 13
Thread: 1966 Engine 901/05
    Nov 2012
    Amelia Island, FL
    1966 Engine 901/05
    No Longer Available
    Banned
    Nov 2004
    Scottsdale, AZ
    Later chain boxes?
    Nov 2012
    Amelia Island, FL
    I'm not certain, I don't have the complete history of the motor as it's older than me.
    Banned
    Nov 2004
    Scottsdale, AZ
    Actually that wasn't meant to be a question...
    Nov 2012
    Amelia Island, FL
    Again, not sure if they are original or not. I know the carbs and the trans are not correct for the 66' model year. 66' was supposed to have weber IDA instead of IDTP. These would be correct for a 68 or a 914-6.
    Quote Originally Posted by helosixx View Post
    Your chain boxes are magnesium, which is 68? and up. Either the boxes or case has been modified to make it fit. The top valve cover looks to be mag too. Also your fan assembly is not '66 but 69 and up.
    I think you need some experience / knowledge to see what your engine consists off. The longer you look at it, the more one sees. Do you have another picture of your oil filter? It seems to be mounted sideways?
    Best,
    Richard
    Nov 2012
    Amelia Island, FL
    The oil filter that was on the car it came from? The engine was last in a 72' 911
    On the right side of the first picture you posted. The orange filter at 2 o'clock
    Richard
    Nov 2012
    Amelia Island, FL
    I believe that was the only photo I had. Again it was a 72' not a 66' that the motor was in. It's my understanding the motor may have been in a 68 before that car which may have been where the fan came from.
    I missed that it was in a '72 (it was probably add after I replied).
    Richard
