Hi I am hoping someone can tell me what type of distributor would have been fitted to my 11/67 Built 911S, I can't find any specific information on Google. Thanks in advance Toby
Well Bosch is the type, and it has a very fast advance curve. What exactly did you want to know?
My distributor is an after market unit, I want to bring it to original and don't know if I need a cast iron or alloy unit. Should it be a 0 231 159 007 or something earlier?
1927 Lancia Lambda
1940 Alfa Romeo 6C 2500 SS
1946 Alfa Romeo 2500 S Touring
1947 Alfa Romeo 2500 S PF Sedan
1962 Karmann Ghia
1968 911L
1968 911S
1971 911S
Toby Primrose +61415333380
It's a cast iron #J FDR6 with yellow I.D. tag on it.
http://www.thesamba.com/vw/classifie...php?id=1795346
Not mine
andy
67S in pieces
EarlyS: 1358
[SIGPIC][/SIGPIC]
Hello experts!
So, what you are you saying is that the 68S´s also got the yellow tag distributors?? I thought ´68 was black.
Always happy to learn!
Thanks, Radmund
Another thread: http://www.early911sregistry.org/for...se-distributor
S-Reg #1382
67S Lavender
Both the manual and spec book show that number, I'm not aware of any other distributor.
I was only wondering about the color of the tag, not the number.
S-Reg #1382
67S Lavender
I have rebuilt many of these, and still do.
To my knowledge, the original 002's for both '67 and '68 had yellow plates.
Here are two more I'm in the process of rebuilding.
These distributors all had date codes stamped into the housings, although often they are difficult to read.
Of these two, one is stamped 708 (August 67), the other is either ?08 or 80?, I cannot make out one digit.
A distributor manufactured in August '67, at Bosch, was most likely used on a 1968 model engine.
All the period Porsche publications, the Workshop Manual and Technical Specifications booklet, list the Bosch 0231159002 "with yellow label".
Jon B.
Vista, CA
