Thread: '66 Pedal cluster
    '66 Pedal cluster
    I'm rebuilding my 1966 pedal assembly. Is replacing the roll pin a requirement? I removed the original pin using a punch. However the new pin will not go in. Should I take the unit to a shop and press it or continue using the original?
    Thank you.
    My old one went out quite smoothly as well, they can be very nasty sometimes. I put the old one back in and as long as there is enough resistance when driving back in I don't see a problem.
    Michael Moenstermann
    Osnabrueck - Germany
    Early 911S member #1052
    'While accelerating the tears of emotion have to flow off horizontally to the ears.'
    'Understeer is when you see the tree you are hitting, if you only hear the tree then it was oversteer'.
    'You can't treat a car like a human being - a car needs love'. (all Walter Röhrl)
    Oct 2009
    Indiana
    if you got the old one out with reasonable effort, and it fits the new assembly tightly, it wouldn't seem necessary to make your life complicated. i had to use a torch to heat my assembly enough to drive my roll pin out with a punch, so i didn't trust mine.
    Many roll pins sold are Yankee not metric, get one from Porsche or a known source.
