Thread: Oil temp gauge not working: Is '66 gauge compatible with '70 2.2 sending unit?
    Senior Member eaton's Avatar
    Nov 2009
    DC/Montana
    I've finally got all the gauges working in my '66 912 with a 2.2 transplant, except the oil temp gauge. When I start the car, the temp gauge immediately maxes out. Does anyone know if the gauge and sending units are incompatible?
    Joe
    '66 912 with a 2.2
    '62 Lotus Seven S2
    '66 Lotus Elan
    '63 Karmann Ghia convertible
    '76 Alfa Spider
    Nov 2009
    DC/Montana
    Further research tells me that no, they are not compatible. Anyone have a used SWB temp sending unit they want to part with?
    '66 912 with a 2.2
    '62 Lotus Seven S2
    '66 Lotus Elan
    '76 Alfa Spider
    Sep 2012
    Philadelphia, PA
    The sending unit needs to match the gauge, not the engine. I had the same problem; 72 911T with 77 2.7 engine. It took a while, now the gauge reads normal with the correct sender.
    Serge
    Early S Registry #2457
