Thread: Help! Turn signals/flashers only work when headlights are on
    Sep 2012
    Colorado
    I've seen a lot of threads about turn signals and flashers only working when headlights are off. I have the opposite problem on the '69 T I'm restoring. The headlights and flashers only work when the headlights are ON. Any suggestions?
    Thanks in advance,
    Rich
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    The Hazard and Head Light switch share a number of terminals on the back of the switches. I'd suggest that the PO has wired up the power to the hazard switch from a switched position on the head lights.....
    Pull both switches, and check the terminal wiring to the switches.
    SL33 is the one you want.
    Tony
    Sep 2012
    Colorado
    Thanks. Will do.
    Rich
