Results 1 to 10 of 17
Thread: Exhaust & Heat Exchangers from 1973 911T Motor
    Junior Member
    May 2015
    White Rock, B. C.
    Just pulled a 2.4 L 1973 motor & transmission for my project out of a donor 71 911 T.
    Exhaust and heat-exchangers are available, good condition. $ 200,00 (Canadian Funds)
    Also, Air intake Cover (Candy Apple Red) w. Filter very good Condition: $ 300.00 (Canadian Funds)
    Maybe more parts from donor coming.
    Body had been poorly modified to wide rear whale tale,
    with lots of Bondo, and broken suspension/subframe parts.
    I am in Vancouver/Canada area.
    Cheers
    Ivan
    Member # 3249
    Quote Originally Posted by Ivan View Post
    . . . Just pulled a 2.4 L 1973 motor & transmission . . .
    Exhaust and heat-exchangers are available, good condition . . .
    '73 MFI? . . . photos would really-really help
    And thank you for posting your member#!
    Oh ---- and welcome aboard!
    Junior Member
    May 2015
    White Rock, B. C.
    Exhaust & Heat Exchangers from 1973 T Motor
    Picture before removal of engine.
    Has 40 IDA's (Weber carbs).
    More parts from the donor car maybe available,
    will know more later on.
    Cheers,
    Ivan
    If the muffler is an original leisritz in good shape, I'm interested. Pics?
    Jordan
    Quote Originally Posted by jc4me2 View Post
    . . . If the muffler is an original leisritz in good shape . . .
    Feb 2014
    Austin, TX
    I see that the engine has Weber carburetors, not MFI or CIS. And since the engine is in Canada, I'm wondering if it is a Type 911/57 (RoW 2.4) that came with Zeniths carbs, that were changed to Webers at some point. If so, I am looking for a 911/57 for my RoW '73 project if you know of one available (or a case).
    '73 RoW 911T (project)
    '77 911S
    Early911SReg #2945
    Junior Member
    May 2015
    White Rock, B. C.
    Hi Frank,
    Actually this was an American car, 911 T, 1971 originally.
    Only Motor is a 1973.
    Chassis # 911 121 0282 (VIN #).
    Cheers
    Is the motor for sale ? If so what is the number on it? Thanks casey
    Feb 2014
    Austin, TX
    Hi Ivan,
    Actually, it is a 1973 911T RoW motor (Type 911/57) that I am looking for, which is why I was asking about the engine once I saw that it had carbs.
    -Frank
    '77 911S
    Early911SReg #2945
    Junior Member
    May 2015
    White Rock, B. C.
    Hi Frank,
    Well it is a 73 911 T motor,
    # 6131919, has IDA 40's type 501 5.
    Can You tell what type it is ?
    Cheers,
    Ivan
