Results 1 to 8 of 8
Thread: Are all 65-73 door roll-up glass windows sized the same?
    Senior Member GT3DE's Avatar
    Nov 2012
    Arlington, Virginia
    I have a 73 that I have installed an earlier frame so as to get the venting 1/4 window. The frame is installed but now the big roll-up window seems to be too short (front to back). We put in new rubber (from Porsche).
    So I am wondering if the window glass came in different sizes.
    Experts any help here would be appreciated.
    Thank you,
    Clarke
Size:  72.2 KBName:  20150605_140526.jpg
    Clarke
    Early S Registry member #3172
    Current
    Race: 10 GT3 pca-GT2, (2) 78 911 pca-E 3.2L
    Street: 05 997S Launch, 75 911S Gemini Blue 3.0L, 68 912
    Past
    68 912, 68 911, 69 911T, 71 911T, 72 911T, 73 911T, 73.5 911T, 75 911S, 77 911, 82 911SC, 91 964 C4, 02 996 cab, 05 997S Launch, 06 997 C4S cab, 10 Cayenne GTS, 11 GT3RS, 11 GT3RS
    "I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." Arthur
    Aug 2009
    SF Bay Area
    I can't tell for sure from your pictures but it appears that you used 66 or 67 window frames. Those are made of brass and take a different window channel felt/rubber than a 68 or later frame. That is probably most of your problem. 68 window frames with vents are made of aluminum and take the same felts as your 73. Buy window channel rubber for a 66 car and you should be OK. You did add a few pounds to your car in the process, if that matters.
    Jim
    Nov 2012
    Arlington, Virginia
    According to Porsche PET, SWB windows are larger than LWB.
    Found some glass from older SWB and it is longer. Problem solved.
    Clarke
    Current
    Past
    Nov 2012
    Arlington, Virginia
    Weight not a concern for this street cruiser. Going to add some more weight with a 3.2L this summer.
    With the race cars I have enough weight issues.
    Saving my energy for the weight game when I build a 911R from one of my 68's.
    Clarke
    Current
    Past
    Aug 2009
    SF Bay Area
    Quote Originally Posted by GT3DE View Post
    Be sure to put the proper seals in the frames. There is some variance in size of the glasses but they are all somewhat the same and interchangeable. The track at the bottom of the window is positioned differently, though and will not work with your "LWB" window regulators. I'll bet your "problem" isn't solved just yet.
    Jim
    This ain't my first Rodeo, as the saying goes.
    Nov 2012
    Arlington, Virginia
    SWB vs LWB windows. Aligned at bottom.Name:  20150610_142821.jpg
Size:  50.7 KBName:  20150610_142809.jpg
Size:  87.1 KBName:  20150610_142759.jpg
    Clarke
    Current
    Past
    Aug 2009
    SF Bay Area
    The track on the bottom of that window is neither a "SWB" or a "LWB" it is a track for a later replacement "scissors" type window regulator.
    Ciao
    Jim
    Nov 2012
    Arlington, Virginia
    Correct, I have later scissor types in my doors. That don't work well!
    Clarke
    Current
    Past
