Results 1 to 10 of 10
Thread: Drivers side durant mirror location
    Jul 2012
    Kent, UK
    SWB Drivers side durant mirror location
    Hi
    I am using later side impact doors on my 1968 911s restoration (this is a UK car).
    I am looking to add large durant door mirrors but will need to drill out holes.
    Looking at the doorframe, there are two small indents where two approx 12mm holes where on previous model year frame.
    Am I correct that these holes should be drilled out from frame through the skin with approx6mm drill, then widened on the frame to 12mm circular hole, that would accommodated a socket fitting to attach the mirror ?
    Many thanks , Rich
    Rich
    68 911S
    mbr. 2393
    Not sure I understand what you have? I believe all doors had access holes in the inner panel to allow a socket to tighten the nuts on the 6 mm screws that were part of the Durant mirror. I assume your mirror has 6 mm studs for its attachment, therefore 12 mm holes would be overkill..
    Port Macquarie, Australia
    Hi Rich
    I know what you're trying to do and yes, those divots are the drill-bit locators for mounting a RHD driver side mirror...
    As you've probably worked out, the mirrors are located asymmetrically on each door and the location is opposite LHD cars.
    John Forcier
    EarlyS #1987
    Restoration Saga
    Jul 2012
    Kent, UK
    Hi John, thanks for getting back and for including pictures! Would you agree suggested hole sizes to drill? 6mm and 12mm? Or did you drill larger?
    Many thanks Rich
    Rich
    68 911S
    mbr. 2393
    I had to go larger than 12mm - I think I went to 15mm as you need room for the thickness of the average socket. Measure other similar holes on your door as I think they are a uniform size. I'm nowhere near my cars right now and can't tell you for sure.
    Cheers
    John Forcier
    EarlyS #1987
    Restoration Saga
    Oct 2010
    Southern Ca.
    The mirror hardware access hole accepts the rubber plugs used on the rest of the door .
    Feb 2011
    Surrey, UK
    Quote Originally Posted by Richy View Post
    ..... which are for a 20mm hole
    Jul 2012
    Kent, UK
    Will go for 20mm holes on the internal frame, 7mm on the door skin. The mirror stud is around 6mm so this will give me a little room for paint.
    All goes well we start painting this week.
    Thanks for the help.
    Rich
    Rich
    68 911S
    mbr. 2393
    Apr 2011
    N.Calif., south of SF
    Recently had a discussion about the right-side mirror holes. We believe that these mirror mount holes were for RHD cars.
    The observation to pass long is, from the driver's seat on a LHD car, can one actually utilize the right-side mounted mirror mounted in that location?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Quote Originally Posted by Haasman View Post
    Yep - OP's car is a right hooker.
    John Forcier
    EarlyS #1987
    Restoration Saga
