Not trying to copy our friends over on "The Bird", but I think it'd be beneficial if we had an engine rebuilding forum on the early s. Opinions on this?
1971 911t coupe
2002 Camaro z/28
Sure.
If you want a hundred different opinions on any given procedure.
Some of them even worth using.
True! A LOT of misinformation floating around out there....
By the way, did you get my PM Frank?
1971 911t coupe
2002 Camaro z/28
Get a factory manual, engine disassembly/assembly gruppe obviously. Read. Re-read. Not much else needed except for some practice and experience. Following directions and not deviating from procedure one should be fine. A lot of the stuff is universal- torque sequence, installing rings, bearings, gaskets and what nots. Only thing really different is cam timing because it's semi fully adjustable ( most cars one lines certain marks for cam timing, 911cam timing is a bit more complex but the instructions make it doable).
But, as you have said, there are multiple ways to do everything. Some are right though. Factory manual explains everything really well. Much better than Audi, which says, "remove, install in reverse order."
None the less, can't wait to see your engine back together.
Ryan Billy, Grasshopper learning from the Grand Master.
Yes - I have a full set of photos and events and a disaster ...
Merv
Member # 2633
Cars:
Porsche '68 - 911N (Sold)
Porsche 356B (T-6) S Coupe
Porsche 2010 Gen.2 Boxster S
Sebastian, See the Tech post on 'Distributor drive gear".
merv
Merv
Member # 2633
Cars:
Didn't see any pics in your thread Merv....
1971 911t coupe
2002 Camaro z/28
Will post a thread from 'go to whoa' when I get all the photos and details Sebastian. I have most of the text ready now. Thanks for starting this thread which can identify some of the issues with early cars.
Merv
Member # 2633
Cars:
