Thread: FS: pair of early production Weber IDA carbs
    ****SOLD*****a pair of very early production Weber IDA carbs. pre-dating the modified casting to incorporate the IDS enrichment circuit. also have brass inside the fuel inlets.
    would have been cast before mid 1966, and correct for engines possibly as late as early 1967.
    no discernible shaft play. soda blasted and ultrasonically cleaned. with brass floats and the hardware to assemble. includes two rebuild kits ( the good ones with the check valves and caps ).
    $2500 shipped. thanks, Don.
    more pics.
    bump......
