Results 1 to 8 of 8
Thread: New fuchs- any body purchased these
    I am thinking about buying a set of the newly available 9 x 15 fuchs wheels- any body here have any comments on these.
    Phil
    Early S Junkie # 658
    May 2005
    Oroville, CA
    Yes, quite a few.
    They are similar to the very last evolution of the 8X15s.
    Except for the outer offset machining is deeper...and sharper.
    The finish is generally pretty good. A little worse than the 7&8X15s but way better than the 16s.
    I have some more detailed photos but I can't find them now....
    You can barely see the deep/sharp outer machining in the end of the spoke to the right of the bottom.
    It is almost 5mm deeper than the original 9X15s.
    Overall a good wheel and value. IMHO
    H
    Harvey,
    Thanks, appreciate the information.
    Phil
    Senior Member NickP's Avatar
    Mar 2006
    Solana Beach, CA
    Are the new version cast or forged?
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
    Senior Member nvr2mny's Avatar
    Mar 2012
    Kansas City
    I bought a set of the Zuffenhaus wheels for our '86 Targa hotrod project. They use Harvey to finish (in the RSR option at least). Very, very nice wheels. LOOOONG wait time and pricey, but worth it IMHO.Name:  image.jpg
    Hi Phil, like Harvey we have also bought quite a few sets of these now, plus the 8s. They are forged as they were original. The finish under the black paint is pretty poor, so if you wanted to back date the appearance they will need polishing first. We have done this to frosted finished, polished petals etc and the results like Harvey said are very good value when you consider the cost of an original pair.
    In case a pic helps?
    HTH
    Alan
    Thanks everyone- I am considering a set of 9 x 15's for the rear of my 76 turbo that is currently being restored- sounds like if I want them to match the fronts I'd need to buy new front wheels as well.
    Phil
    May 2005
    Oroville, CA
    As you can see from my photo, the new 8s aren't really a match.....
    H
