Hi all-
Thanks to Jim and John at EASY, I was able to install the rear window heat harness into my '69E. The harness was removed from a '69 912.
The wires are fed from the engine compartment through a hole almost directly above the fuel filter.
The Kroon harness has one wire coming from the relay.
So I jury rigged the female connector.
Now to install the rear window...
