Results 1 to 2 of 2
Thread: Distributor stuck in the case
    OK, so what is the best way to extract a Marelli distributor, that is stuck, from the case?
    Banned
    Nov 2004
    Scottsdale, AZ
    Ted,
    Clamp is loose and 8mm nut is removed, right?
    Spray penetrating oil at the base and pull/rotate back and forth like you're trying to wrestle your way out of a plastic bag.
    If that doesn't work get the slide hammer out. Keep in mind it's a Marelli we're talking about here; it probably needs to be thrown away when you finally get it out.
