Results 1 to 10 of 18
Thread: Bendex fuel pumps
    Bendex fuel pumps
    Does anyone have a source or solution to fuel pump gasket for the lid of these fuel pumps. Gordon
    Nov 2014
    Port Orange, FL
    The Bendix pumps are now known as "Facet" pumps and are available in the US from a number of sources:
    http://www.finditparts.com/products/...FUc8gQodZ78EVw
    Aircraft Spruce: http://www.aircraftspruce.com
    Jan 2011
    Sunny Southern France
    Gordon,
    May it fit your needs?
    http://www.aircraftsupply.com/ca42370.html
    Olivier.
    Thanks for the input. G.led
    Nov 2002
    San Dimas, CA
    If you can afford to pay almost $ 9.00 you can buy Fuel Pump Gasket & Filter Kit - Universal Electric BK 6101086 at NAPA.
    Unfortunately, you can only buy it together with a replacement filter, hence the whopping $ 8.99 price...
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    I ordered a pair from Aircraft Spruce today as suggested by Oliver. Thanks all
    Jan 2011
    Hope that I pointed you to the right parts...
    Thanks all, new gasket, exactly like original, new filter, fit perfectly, works and doesn't leak. Old parts vs new. Gordon
    Jan 2011
    Gordon,
    If i'm not wrong the original filter is sinered brass. You can clean it and reuse it. I think it is more efficient than the plastic screen one.
    BTW, where do these pretty argus fitting come from?
    Olivier.
    Nov 2002
    San Dimas, CA
    My big question is: how did you get the pump re-plated and shiny? does it have to be completely disassembled, and if so, how?
    Jim Alton
    Torrance, CA
