Hi, Would someone please send me a picture of the location of the VIN decal on the door post 73 911. Dimensions would be very helpful.
Thank you, Fred
Thank you, Fred
Actual location varies some from car to car. Believe they where just hand applied while the car moved down the line, just need to get it in the approximate area.
You should be able to google it and find tons of photos.
Mark..
Thanks Mark
do a search on this site and even go to google images - u will find a million pics and you can get an idea of the placement
Early 911S Registry #750
1970 911E - The Good Stuff
2001 Toyota Landcruiser
Here is a picture of one.
E Sully
1973.5 911T
Digging up old post….
I think 71 location and description may be different , can someone post 71 and also the rear engine panel for decals
73.5 Snrf T
71 Snrf T
70S targa
76 914 2.0
82 Targa,
85 Alfa GTV6
60 Lancia Appia Zagato GTE
Depends . . .
. . . if we're talking about a NA car
Euro-market cars won't have a sticker on their B-pillar --- or a tag on their A-pillar . . . at least not from the Faktory
This is an OG Euro car + personal import . . . VIN tag was added later, at some point . . .
https://www.early911sregistry.org/fo...hmentid=245763
From what I can research the term “Passenger Car” on the tag as shown above and also on my 73 , but 71 and maybe 70 did not have that as the first line ? Can someone also verify .
Several posts here and the Bird suggest there was no precise location but I found an original 71 and was able to blow up until the size matched the label, measured from the bottom where the offset curve at sill and the dimension off the vertical along the gasket . Used these dimensions to position mine.
So maybe acceptable
These were US cars as is mine
Sully’s position matches locations I have seen
73.5 Snrf T
71 Snrf T
70S targa
76 914 2.0
82 Targa,
85 Alfa GTV6
