Results 1 to 1 of 1
Thread: FS: 1989 Porsche 911 Carrera Convertible
    Senior Member Orbit's Avatar
    Oct 2010
    Jupiter , Florida
    PRICE: $60,000
    VIN WP0EB0918KS171338
    Black paint, Black interior, Black top – Triple black
    54,371 miles, good service records that validate mileage to be original
    Factory Warranty and Maintenance book with original dealer stamp from Paul Miller Porsche.
    Power Top, A/C
    MECHANICAL DESCRIPTION
    Major Service at 54, 350 miles
    *Engine Oil and Oil Filter
    *Air Filter and Fuel Filter
    *Valve Adjustment and Spark Plugs
    *Distributor Cap and Rotor
    *Alternator and A/C belts
    Miscellaneous Repairs
    *New Oil line from tank to engine
    *Replaced from crankshaft seal
    *New right side cam oil feed line
    Cylinder Leakdown
    1. 6% 2. 8% 3. 8% 4. 8% 5. 8% 6. 6%
    Compression Test
    1. 130psi 2. 130psi 3. 130psi 4. 125psi 5. 120psi 6. 130psi
    Suspension
    *Front Struts
    *Rear Shocks
    *Front A-Arm Bushings
    *Front Turbo Tie Rod ends4
    (All replaced in 2014)
    Tires
    New at 54,350 miles
    *Front Goodyear 205/50/16
    *Rear Goodyear 225/50/16
    Brakes
    Replaced at 54,350 miles
    *OEM ATE Front Brake Calipers
    *OEM ATE Rear Brake Calipers
    *Brake Master Cylinder
    *Front and Rear Brake Pads
    *Rear parking brake shoes
    *Steel braided brake lines
    Air Conditioning
    *New A/C dryer
    *New front condenser fan motor
    *Fully charged and leak tested
    Additional Mechanical
    *New Battery
    *New Hood shocks front and rear
    *New transmission oil
    *New front wheel bearings and seals
    *New brake fluid reservoir
    *New front hood latch
    BODYWORK AND CHASSIS
    Convertible Top
    *New Convertible top at 54,350 miles
    Please Contact Rodger@orbitracing.com with any questions
