Thread: What's the trick (seat belt plastic trim/bolt)?
    Hi all-
    I must be doing this wrong. How are the seat belt ends bolted in place without destroying the plastic trim?
    Thanks a lot in advance!
    Cheers,
    Ron
    1961 356 Roadster Outlaw
    1969 911E ROW Coupe ‘Orangina’
    1968 911 SWT Burgundy Red project
    Junior Member
    Dec 2010
    Essex UK
    Ron,
    do you have the shouldered spacer under the webbing metal bracket to post fixing hole?
    Regards David
    36 year PCA member
    Dec 2012
    Denver Co.
    17mm open head wrench. It is slow but that's all that can be done
    Keep doing what you're doing,,,,push enough belt through that plastic surround and you can easily get to the bolt head.
    Apr 2012
    Simi Valley Ca
    I just started taking the interior out of my 69S last week, and I am stuck here too. I don't know how Ron got to the point he shows in the pic above. The metal piece hangs down farther than the hole in the cover?? Seems that there is no way to pull the metal bracket and the plastic piece on the left of it out of the cover? Any help appreciated.
    Bob B
    Found my answer. Ron. I think this picture will help you.Name:  067.jpg
