Thread: 3M Rust Fighter 1
    3M Rust Fighter 1
    Has anyone had experience using this product in internal areas such as the void between the front suspension pan and the tank support or in the longitudinals?
    Or do you have a recommendation on a seam filling/penetrating product for rust prevention.
    Also what have you used as an applicator?
    Thanks!
    no experience but some other forums are all gaga over Fluid Film
    I've used it inside the doors, to help prevent rust. I would imagine you could use in the void areas, but for a new installation otherwise id worry of just encapsulating existing corrosion.
    I've just sprayed it into the doors.
    This is basically just a Waxoyl type product that goes in liquid and then sets into a waxy film.
    It takes awhile for the smell to go away.
