Results 1 to 10 of 18
Thread: Oil Pressure Sender Help
    Oct 2010
    Florida
    I'm getting some wild gyrations on my oil pressure gauge. Buz at Seattle Speedometer suggested I replace the sending unit before I get crazy and send him the gauge.
    My problem is there are so many sending units for sale. Prices are all over the place. This is a 1973.5 engine. What, and from who, would you suggest I purchase?
    Name:  911 Oil Press. Sending Unit.jpg
    Richard Newton
    Aug 2011
    New York
    Here are 2 options, both URO. Pelican is slightly cheaper.
    65-216814-1 http://www.automotion.com/oil-pressu...1965-1973.html
    901-741-551-02-M253 http://www.pelicanparts.com/catalog/...ENGOIL_pg4.htm
    E Sully
    1973.5 911T
    Banned
    Nov 2004
    Scottsdale, AZ
    Typically uro means urine.
    In this case it's crap.
    Oct 2010
    Florida
    Ok Frank. What would you buy?
    Richard Newton
    Banned
    Nov 2004
    Scottsdale, AZ
    I think I may have an extra new VDO.
    I'll check.
    Banned
    Nov 2004
    Scottsdale, AZ
    You need 911 606 111 02. No gots in VDO.
    Sorry.
    I have the 901 senders in VDO.
    Aug 2011
    New York
    901-741-551-01 was original part number, superceded to 901-741-551-02.
    911 606 111 02 is for 74 on.
    E Sully
    1973.5 911T
    Banned
    Nov 2004
    Scottsdale, AZ
    I believe his photo shows a 911 606 111 02.
    Richard, if it is in fact the 901 part you need I have them available in VDO.
    Oct 2010
    Florida
    I probably need the 901 part. It's a 1973.5 with CIS.
    I have no clue if mine is the original sending unit. I just know it's been in there for the past 30 years. It can't hurt to go back to the original unit. Right?
    Richard Newton
    Aug 2011
    New York
    I don't know what sender is in the photo, but I know what my 1973.5 uses.
    If Frank has a VDO then great, if not the URO will work.
    Make sure your electrical connections are good. Power is supplied to the gage by the Bk/Rd wire on the back. It is then connected to the sending unit with the Grn/Rd wire.
    The sending unit works the gage by varying the resitance to ground. A poor ground strap, or connection in the 14 pin connectors could also cause problems.
    E Sully
    1973.5 911T
