Thread: Tarett camber plates + Koni adj. dampers - How to keep the piston from turning?
    Feb 2012
    Sweden
    Hi
    I'm in the process of rebuilding my front suspension with Boge struts, Koni adjustable dampers, and Tarett monoball camber plates. How do you keep the damper piston from turning when tightening the large nut? When using the stock rubber mounts the top plate/washer has a "tooth" that locks in to the groove of the piston, keeping it in place. Other dampers either use a hex key or smaller spanner to hold it in place.
    What to do? Is there a tool that can assist holding it in place?
    Cheers!
    Johan
    -70 911E
    -84 3,2 Sold
    Banned
    Nov 2004
    Scottsdale, AZ
    Yes. The "special" tool is called an impact gun.
    Apr 2011
    N.Calif., south of SF
    If I recall correctly, running into the same problem some time ago, I started the nut (with all the washers, rubber bushings etc in place) then raised the the car just little, enough to put tension on the top of the shock rod. The tension kept the shock shaft from turning. It worked!
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    mad scientist
    Apr 2007
    Austin, TX
    you can grab the outside of the keyed washer with some soft jaw pliers and then tighten as normal.
    1971 911T SWT - Sun and Fun Machine
    1972 911T - "Minne" painted and undergoing assembly.
