Results 1 to 1 of 1
Thread: Seat belt buckle restoration
    I need to rechrome an early seat belt buckle and figured out that the "pin" that holds it together is constructed of two pieces. There is a main shaft with a recess that is combined with a press-in fitting at the other end. I had to grind of the head of the press-in fitting to remove the pin/shaft from the buckle. So all that being said, (hope it makes sense,) does anyone have a source for the two part pins or know of a service that can restore the buckle? Any help would be appreciated.Name:  DSCN1969.jpg
Size:  113.6 KBName:  DSCN2011.jpg
Size:  94.5 KBName:  DSCN2009.jpg
Size:  16.6 KBName:  DSCN2012.jpg
