Thread: 70 2.2L Tuneup - What do you think?
    Member RW7810's Avatar
    Dec 2003
    Van, TX
    Doing a much deserved tune up on my 70 911T. oil, plugs, valve adj, etc. The plugs on the right bank, cyl 4-5-6 are very black and sootie, the plugs on the left bank, 1-2-3 look pretty good. Should I just turn in the mixture screws on the right bank a half turn or so ?
    Name:  plugs 1-2-3.jpg
    Name:  plugs 4-5-6.jpg
    Robert Williams
    911T
    Member #1611
    Mar 2013
    Surrey, UK
    I'd balance the carbs first. As all 3 on one side look the same, that could be your problem.
    Dec 2003
    Van, TX
    update.....turns out #1 and #3 cyls weren't firing! Engine ran and sounded good, so now I need to figure out what's going on.
    Robert Williams
    911T
    Member #1611
    Senior Member eaton's Avatar
    Nov 2009
    DC/Montana
    I've found Paul Abbott's carb tuning and maintenance primer invaluable in getting my car running right. Be sure to also check the resistance in your plug wires with a multimeter. Bad wires were the culprit in my case. Seems 40-year-old plug wires do go bad, eventually.
    http://www.performanceoriented.com/new-page-2/
    '66 912 with a 2.2
    '62 Lotus Seven S2
    '66 Lotus Elan
    '63 Karmann Ghia convertible
    '76 Alfa Spider
