Results 1 to 10 of 13
Thread: '70 911T Died then came back to life
    I drove my '70 911T off an on over the weekend with no problems. Sunday afternoon I came out of a restaurant and it didn't start right up like it usually does. It struggled for just a bit but then fired up. On my short drive home and about a mile from home the car basically shut down completely. I coasted into a parking lot. The car cranked just fine but would not fire at all. To me the symptoms seemed like out of gas, however the gauge read about 1/4 tank. I thought the gauge might be off so I walked home and got a gas can. Went back to the car and put in two gallons of gas. Still would not start. Waited about another 15-30 minutes and car started right up. I was hoping it was just out of gas but when I went to fill it up it only took about six gallons. I am a bit nervous driving it now as I am afraid it could shut down again at any time. Any suggestions on what could have happened or what I might check. THANKS!
    Kevin
    Early 911S Registry Member Number 3210
    1960 356B
    1970 911T
    1985 Mercedes Benz 280TE
    could be an intermittent electrical problem
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Senior Member csbush's Avatar
    Jan 2009
    San Antonio Texas
    Really could be a number of things. I had a similar problem though, and it was crud in the gas tank blocking the intake screen. Being low on gas would exacerbate that problem. Could be a CD box or coil malfunctioning when hot, but I would start with the gas tank.
    Chuck
    Early 911S registry #380
    '70S
    '75S
    '96 C4S
    '65 R69S
    Quote Originally Posted by csbush View Post
    Thanks. Will check out the gas tank first.
    Kevin
    1960 356B
    1970 911T
    Quote Originally Posted by Marken View Post
    I don't know where to find the screen filter on the tank. Is it underneath? Do I need to drain and remove tank? Also, the car has Zenith carbs now. I also looked for the cartridge filter in the engine compartment and didn't see it. See photo. I followed the fuel line to the carbs and see what looks like a filter at each carb. See photo. I probably should remove and clean or replace them while I'm at it.
Size:  69.4 KBName:  driverside.jpg
Size:  74.6 KBName:  passengerside.jpg
    Kevin
    1960 356B
    1970 911T
    Aug 2009
    SF Bay Area
    Your CD box is dying. Your symptoms are classic.
    Jim
    Jim
    Thanks. Is this something a novice can replace? Are there adjustments to make after installing? Sorry for all the questions.
    Also, you can see the CD box in one of the above photos. There is a red wire that is hanging down that is not connected to anything. Do you suppose that is OK? Thanks!
    Kevin
    1960 356B
    1970 911T
    Can a CD box be rebuilt?
    Peter Kane
    '72 911S Targa
    Jan 2011
    DFW TX
    I had the same symptoms once and it was the CD box.
    Easy to replace.
    Don't know what the red wire is... Not coming from the CD just behind it.
    I installed a "rebuilt" CD from Parts Klassik recently and am very pleased with it.
    Quote Originally Posted by M_deJong View Post
    Easy to replace.
    Thanks. I will do this and also clean out the fuel tank as well.
    Kevin
    1960 356B
    1970 911T
