Thread: 1971 S Wheel wells painted with clear undercoat
    I know this question comes up from time to time, but recently I've seen a new trend...
    What is the consensus on painting the wheel wells body colour (Yellow in my case) and then painting clear or tinted undercoat over them?
    What about the trunk and engine compartment? They could be done the same way.
    I know the original process is a bid crazy, they primed everything, undercoated, and then sprayed body colour over the undercoat. I believe some parts (trunk and engine compartment) where hand painted with satin black over all of this.
    One more item.... The suspension. Can I powder coat the suspension or is that not done in the concours world?
    Thank you in advance,
    MaseratiSD
    Senior Member beetle08's Avatar
    Oct 2010
    Seattle, WA
    Regarding the suspension pieces; powder coating is not concours. However, for longevity, several peeps have powder coated than painted over with the correct black hue. Just make sure you don't coat contact and threaded areas.
    Cheers,
    Mauricio
    Three Pedal Posse
    Member # 1935
    1968 Porsche 912-6 TR Tribute
    1968 Porsche 911 L
    1973 VW Sportsbug
    1974 Porsche 911 S
    1991 Porsche 964 Carrera 2 3.8
    "if you see a fork in the road, PICK IT UP!"
    an epoxy paint might be better and the right color too
Tags for this Thread
