Results 1 to 8 of 8
Thread: Disassembly of rearview mirror
    Mar 2012
    Mishawaka, Indiana
    I have a 68, quick release rearview mirror and I can't get the rearview mirror/ball joint seperate from the mounting bracket. Does anyone have experience at how to do this without damaging the mirror?
    I need to detach the mirror from the left bracket and attached it to the newly rechromed right bracket. It appears to be a threaded connection, and I've used penetrating oil but have no way to get a good grip on the ball connection. Any ideas???
    LarryName:  IMG_6078.jpg
    Larry Dunville
    • 1968 911S Targa Softwindow
    • 2002 996 Carrera
    S Registry Member #2247
    You could heat up the area where the ball goes into the socket, then pull the ball out of the back of the mirror, then mount the ball in a vice with soft jaws so as to not damage the ball, and then unscrew the bracket from the ball. Then do the reverse, after gently heating the back of the mirror, and then just press the ball into the socket and you're done.
    Steve Meltsner
    Nov 2003
    Santa Monica CA
    What about putting the black mirror in hot water to heat up for ball removal?
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    I suppose you could do that, but since I personally don't know what's behind the mirror, I'd be uneasy putting the whole thing in water. What would happen if there's some cardboard or some such material behind the mirror?
    Steve Meltsner
    Sep 2009
    UK
    Steve, there is a cardboard on the back of the mirror. Was on mine.
    That's the reason to not dunk it in water. Just use a little heat from your better halfs hair dryer. Will work nicely.
    Steve Meltsner
    +1 to what Jetjok said. If you put the mirror face down and push the bracket towards the plastic body after heating the plastic it will pop out. Put something thin/flat on the plastic to protect it from the bracket as you push.
    Member 1488 MrJTP2001's Avatar
    Nov 2008
    Denver area
    I used a heat gun, very carefully, to warm up the joint, lubed the ball to reduce the friction and carefully pulled it out with a twisting motion. Worked fine. After restoring the metal bracket I put it back together while warming it again and using a little lube. This was on my 68 but the part you are replacing was the original part on mine. No chrome.
    Tony
    68 Sporto Project
    2016 Boxster
