Results 1 to 9 of 9
Thread: SWB front bumpers large light covers or small?
    Jul 2012
    Kent, UK
    Have moved on from durant window location, to the front bumper.
    Am interested to know when bumpers switched from the small holes for the lights to the larger holes? I have a bumper with smaller holes fitted to a SWB UK RHD 68S.
    What would be the technically correct bumper?
    Rich
    68 911S
    mbr. 2393
    Feb 2007
    Cheshire, UK
    Rich
    This is the correct one for '68:
    Tim
    Early 911S Registry #1167
    Jul 2012
    Kent, UK
    Hi Tim , do you know if this bumper has the bigger or smaller driving light holes ?
    Thanks Rich
    Rich
    68 911S
    mbr. 2393
    Feb 2007
    Cheshire, UK
    Hi Rich
    I thought there was only one type of swb bumper so I am afraid I don't know what I am comparing them against? LWB bumpers are different with different profile holes I believe although whether they are larger or smaller I am not sure (if I had to guess I would say swb are smaller); I am sure there will be someone on here who can give you a precise answer.
    Tim
    I don't believe the hole size changed, I believe there were two different type of covers, the early type that fit snugly inside the opening and bolted through one of the holes, and a later style that was bigger, and completely covered the opening and had a rubber gasket around it (Restoration Design makes a repro of this style). Not sure when the switch was, but my 67 had the late style on it.
    Feb 2007
    Cheshire, UK
    I should have checked my Parts Catalogue in the first place, '68912' is correct in that there were two different covers for swb the original ones stopping at chassis 305100, they went from having what looks like an angled bracket on the rear of them to a cover that used a separate sealing strip and retaining strap/bar.
    Tim
    later style, couldn't fins a picture of the early style
    Pay to play Schiefer's Avatar
    Jun 2008
    Norway
    S-Reg #1382
    67S Lavender
    Jul 2012
    Kent, UK
    Super helpful, thanks so bumper unchanged but covers changed.
    Rich
    68 911S
    mbr. 2393
