Results 1 to 10 of 17
Thread: Battery size for a 68 911S
    Mar 2012
    Mishawaka, Indiana
    After 3 years of a total resto, the car comes off the jack stands tomorrow. Hopefully, in the next two weeks the rebuilt 2.0 liter and tranny will be installed.
    So it's time to be getting a battery. Does anyone know the physical size of the original battery?
    Larry
    Larry Dunville
    • 1968 911S Targa Softwindow
    • 2002 996 Carrera
    S Registry Member #2247
    Nov 2002
    San Dimas, CA
    All SWB 911s use the same battery: 999.611.010.90 BATTERY 12 V 45 AH 1
    Here are notes I copied from the PCA website:
    Question:
    Hi , I am in the United Kingdom, trying to find the O/E battery for a 912 I would like the dimensions and to know where can I get one.
    Answer:
    The battery that is an exact fit for all early single battery 911s and 912s is a U.S. size 2HN. This was described to me as an "ordinance" battery used in pairs in 24 volt military vehicles such as the Jeep. It is 5 1/4 inches wide, 10 3/16 inches long and 9 inches high. The battery applications list suggests a 22NF which is too short for the tray and cover but will work if you don't care about originality and maximum battery capacity. I have purchased a couple of 2HN batteries from Cargo Battery Co., 303-296-8763, here in Denver, Colorado. They cost about $100. They are sold dry so they can be shipped if you can't find one on your side of the pond. David Seeland - PCA WebSite - 10/12/2004
    From g503.com
    2HN 10 3/16 x 5 1/4 x 8 15/16
    From oreillyauto.com the 22NF is:
    Length (In): 9-3/8 Inch
    Width (In): 5-1/2 Inch
    Height (In): 9 Inch
    By the way, 22NF batteries also fit some Ford tractors.
    Back before there were lots of sizes of Optima batteries, there was an Optima intended for some Honda cars. It was a little narrower then 2HN or 22NF but it would fit. Now, the Optima website recommends the Optima YT R 2.7 which is:
    Length: 237 mm / 9.33 in
    Width: 129 mm / 5.08 in
    Height: 227 mm / 8.94 in
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    The common class of battery today is the 51R. I think all manufactures use this number. Gordon
    Here is a thread I wrote on this topic ten years ago. Enjoy!
    http://forums.pelicanparts.com/porsc...imensions.html
    Senior Member Merv's Avatar
    Jan 2013
    Queensland, Australia
    Thank you. I have been looking for this. I have the original cover and base and this helps.
    Merv
    Member # 2633
    Cars:
    Porsche '68 - 911N (Sold)
    Porsche 356B (T-6) S Coupe
    Porsche 2010 Gen.2 Boxster S
    Senior Member Peanut's Avatar
    Aug 2012
    Florida
    Will you show pics of the car when you are done? Would love to see.
    Scott
    1968 911S
    1986 Carrera
    2006 Carrera S
    Feb 2007
    San Diego
    Use a 51R that is the ticket, the R stands for reverse poles so make sure you do not buy a size 51
    Jan 2017
    East Coast (USA)
    Purchased the Sonnenschein A512/55A from Ft Lauderdale Battery, fits perfectly and looks the part in my 68. Purchased an old style Bosch sticker from a 190SL shop to finish the look, although might have been marginally more correct.
    So the sunshines are available again? Good to know.
    Dec 2011
    Palm Coast, FL.
    The Sonnenchein batteries are back in stock. They only have 15 units on hand at $185 a piece. Got mine yesterday while I was in the area.
    ESR # 2300
