Thread: MFI pump
    Senior Member 993TT's Avatar
    Apr 2013
    Europe
    MFI pump
    Has anyone ever seen a MFI pump with engine displacement stamped below pump's id tag?
    Since the type number is partially destroyed is there a way to identify it by - serial number - or in another way?
    Stacks are from 2.4S/RS (911 110 312 1R).
    Timo
    "There's no point living if you can't feel alive"
    - a few 911s & some others
    Early 911S Registry #3206
    Sep 2013
    Vancouver, WA
    Can you provide a better photo that doesn't have so much glare on the tag? That looks like a 2.7 which is something that would have been done here. In German, their periods are commas and their commas are periods
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    That looks to me that it has been re calibrated and the space cam changed to RS specs some time in the past and stamped 019 at the time to replace whatever specs were there originally. That is how mine was done when it was changed from a 2.4 E pump to a 019 pump. By the look of it whoever did the conversion also stamped the 2.7 so it was very clear what it should be and by the look of it tried to stamp 019 over the original number
    what numbers were under the top 019 stamping. Also what are the numbers / letters on the other plates. That will tell you what the pump was originally.
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
