Results 1 to 8 of 8
Thread: black wire help here please..
    Sep 2011
    Los Angeles California , subburbs
    ok , so have stuck the motor back in .. took a look at the pictures i had on the phone.. seem everything is great except this one black wire..
    i cant figure out where it goes...
    its near the thermostat in the harness.. and is around the carburetor area in the length.. it has a spade on it..
    can somebody chime in for a little help...
    thanks in advance
    lemon
    Well first that isn't a proper euro spade end, that looks more american, secondly there does need to be a wire that goes to that solenoid just beyond your hand. Use a volt meter and find when if ever, is the wire powered.
    Sep 2011
    its powered..
    Lemon
    Sep 2011
    also my handbrake red light is on.. even if i put the hand brake down.. could this be the other side.. it closer to the starter in the wire loom(harness)..
    Lemon
    That wire will have nothing to do with the handbrake. That sure looks like an added wire, but since you say its powered is it always powered or does it come on with the ignition switch? Secondly insulate the end so it can't inadverdantly ground and see if the engine will start. If it does then see what isn't working.
    What year is the car/engine?
    Do you have a meter to test and see what terminal it is in the 14 pin connector it is (if '70-'73)?
    On my 73, i have a black wire going to the oil temp sensor
    Peter Stey
    1973 T Coupe with 2.7MFI
    1970 S Targa (sold but not forgotten)
    Oct 2010
    Southern Ca.
    What the hell ? A little more information would be helpful . Is the car a '70 or '71 that came with MFI and now has carburetors ? Are we taking a test ? How about a larger area pic .
