Thread: inner rocker panel
    Senior Member Robert-Jean's Avatar
    Feb 2008
    Netherlands
    inner rocker panel
    This is the inner rocker panel of a 1966 MY car.
    I believe the inner rocker panel has been replaced in the past.
    Can anyone confirm if this panel is / is not identical to the original panel?
    i just got done with this job on a 66. The inner rocker shown is probably the original although the dark green primer NOS replacement I used has vent holes on the upper side.
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    yep thats the correct SWB panel
    the lwb is stamped a bit different (due to the bigger muffler tube) and has the vents as mentioned above.
    if mr. M.dejonge reads this...hey you still owe me 1k..i`m sure you remember our bet about this topic...paypal is fine
    Feb 2008
    Netherlands
    Both 66S and Moito, thank you very much.
