Thread: What is your Roadbook editor ?
    Aug 2012
    France
    All,
    What do you use as roadbook software to create your itinary ?
    Cheers
    Xavier
    O-G 26 - Early911S 2407
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Roadbook assistant
    http://www.wetexx.de/index.php/softw...book-assistant
    Cheap, even available in french.
    Has some issues that I as a software guy would implement different, but all in all great value for money.
    Did the roadbook for the gathering with it.
    Aug 2012
    France
    Quote Originally Posted by uai View Post
    Roadbook assistant
    Ah ah ah ah !!! I was counting how long it will take for you to jump in
    Thanks Uli, I noted down the name while we were at Stuttgart.
    X
    Jan 2011
    Horb a.N. Germany
    And for planning trips I use http://www.motoplaner.de but you knew that already too.
    Works in europe very well and can export files for import into your GPS.
    It's just an interface for planning tours using the card provider of your choice.
    I like it that much that I promote it whenever possible.
    Cheers
    Uli
