Thread: WTB: Right hand side early aluminium chain case cover
    Hi,
    I'm after a single rhs aluminium chain case cover for a '66/'67 engine (pre magnesium)
    If you can help then please let me know.
    Andrew
    (postage within US)
    bump, still looking . Please PM if you can help
    Jul 2008
    near Ottawa, ON,canada
    , I have a really weird chain cover with a flange connector on it but not hole, is this it ?
    now on the road 914-6
    now in the shop for concourse resto 11850275 S SWT
    daily driver B8 S4 stage 2
    Yours is a left otherwise it would have been what he is in need off.
    Richard
    Hi freezing14,
    this is left side aluminium chain case cover after they stopped using the mechanical fuel pump but before they moved to mag case. This is the most common type of aluminium case cover '66, '67 or maybe '68.(if there is such a things as common)
    There should be a date stamp on the inside.
    The ribbed item is a lower cam cover off for the same engine.
    Do you have the matching pairs of the 2 covers shown in your pictures ?
    This is what the other chain case cover looks like. The other cam cover would look similar to the one you have already shown. I'd have the pairs if you had them
