Thread: LWB Front Fender Conversion
    Apr 2013
    Clayton, NC
    Can a 74+ Driver-side front fender be modified to fit a LWB car? If so, how extensive is the modification? The LWB cars have the turn signal mount as part of the front fender, but I don't know if this mount is available separately or not. Any other differences?
    Thanks in advance.
    Dennis
    Jan 2007
    Phoenix, AZ
    There's some fabrication on top welding the signal mount but this is done on a regular basis. A new LWB fender is about $1200 bucks, the signal mount is about $100-300 plus the labor to weld and fab.
    Apr 2013
    Clayton, NC
    NTW,
    Thanks for the info. I thought someone was manufacturing the signal box so it could be added to a 74+ fender, but I could not find any info on this.
    Dennis
    Nov 2010
    Glen Allan, Ontario
    Dave at TRE makes conversion pieces. You can see what they look like in this thread on Pelican
    http://forums.pelicanparts.com/porsc...nder-kits.html
    1971 911 T Non-Sunroof Coupe
    1984 944 Original Owner
    1989 911 Targa
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    I did mine myself, cut off the turn box's from my original 70 fenders (that where very rusty) and grafted them on to some from a 76. Not hard, just take the time to get everything lined up the best you can.
    Mark..
