Results 1 to 10 of 16
Thread: FS: Mahle Gasburner Wheels - Magnesium, 5 of them
    Senior Member greggearhead's Avatar
    Colorado Springs, CO
    Real Magnesium Mahle Gas Burner rims. 15 x 5.5, dated 1970 (the ones I can read, anyway - can check dirty ones for someone that's concerned). These are rare and aren't always clean - the magnesium is known to corrode quickly and easily, just like VW BRM wheels.
    Five of them so you can have a matching spare. One wheel was painted blue at one point, is partially stripped. One wheel had a crack and was welded and repaired.
    $3800
    Aug 2009
    SF Bay Area
    It wasn't painted blue. Blue is the color of the primer used under the silver paint. The top coat has just worn exposing the blue primer.
    Jim
    Thanks again for the expertise.
    Still available.
    Sep 2013
    Vancouver, WA
    25 years ago I tried to polish a set of these. I gave up after the first one when it turned blue. Boy I sure was confounded. Now it all makes sense.
    Thanks - fair amount of interest from the 914-6 crowd, not as much from the 911 crowd...
    Senior Member Varooom's Avatar
    Oct 2006
    SoCal
    Yes, when I restored my rare Campagnolo's (which are magnesium as well) they were blue-ish under the old silver paint. I would be on those if I had the 5 lug set up.
    Nice hot set those Mahle's! The 914/6 crowd would be first on those! Good Luck!
    Steve Var.
    _____________
    61 356B
    67S
    66 912
    66 Fulvia
    72 914
    So is the blue paint a special primer for magnesium?
    Peter Kane
    '72 911S Targa
    I don't know how 'special' it is, but Mahle used it on their magnesium wheels, so in a qualified way, yes. Thanks for the input Varooom.
