Thread: Reproduction vent drain tube
    Hi Guys,
    Im still working on producing the drain tube that goes from the exterior air intake vent just below the windshield. The first two manufacturers I contacted were a bust. I am now working with a very promising lead that will produce an exact reproduction down to the white inner tubing of the original. I need some help confirming the exterior black finish, is it a gloss black or is it more of a matte finish. Apparently the process and thus the cost will be different depending on the gloss or lack there of. Any help and photos would be much appreciated.
    Please, can someone pull back their trunk carpet to check.
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Tough call... This one seems to be both! The protected inside curve looks a little glossy & the outside exposed side looks a little dull!
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    Aug 2009
    SF Bay Area
    Call me
    Jim
    Thanks Jim, much appreciated. I'm planning a trip up to your shop. I'll contact you soon.
