Thread: 1969 Cable
    1969 Cable
    Dear all,
    I'm looking for this number spar parts : 901 612 068 00
    The electric cable- harness, on the engine of a 2L from 1969 mileage.
    Thanks for your proposal
    Best regards Sebastien.
    Sep 2009
    UK
    i may have this, can you give me a bit more info. Is it a 69 only MFI engine harness.?
    Hi Sebastien-
    You might want to check with Gerard Kroon at Kroon Wiring Harnesses. Gerard rebuilt all the wiring harnesses for my '69E. He sells most of the harnesses individually and should be able to help you out.
    Cheers,
    Ron
    1961 356 Roadster Outlaw
    1969 911E ROW Coupe ‘Orangina’
    1968 911 SWT Burgundy Red project
    Hello Strech,
    Thanks to you, the my is a S one, mechanical injection, a E model is also ok for this type of engine,
    Many thanks in advance,
    best regards sébastien
    Thanks Ron,
    I will have a look there…..
    Many thanks to you
    sébastien.
