Thread: sportomatic pump
    Sep 2008
    Monza, Italy
    sportomatic pump
    Hallo everbody
    i'm searching for the technical datas about this pump ( working pressure, etc) but i can't find them.
    is somebody can help me i appreciate.
    best
    Andrea
    Registry Member #1414
    NOSGRUPPE
    Torque converter oil pump
    Hello Andrea,
    The workshop manual has info, see page SE 17, it says oil flow rate through the torque converter is approx. 3 liters (3.2 US qts. per minute at the maximum pressure of approx. 4 atmospheres (29 psi). The Sportomatic oil circuit is given on pages, SR 48/49. It also gives a caution, if the engine is started while out of the car, connect the Sportomatic oil supply pump to an oil container to reestablish oil flow, never permit the oil pump to run dry...hope this helps
    Ernie W
    member of Early 911S Registry
    Sep 2008
    Monza, Italy
    Ernie
    as usual, you are THE MAN
    thank you
    Andrea
    NOSGRUPPE
