Results 1 to 2 of 2
Thread: Master cylinder - need advice
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    The master cylinder on my '69 911S is over twenty years old but my brakes are working perfectly fine. Should I leave well enough alone or should I proactively rebuild or replace the MC before it fails (most likely on a winding road as my luck would have it)? The calibers have been regularly serviced and the brake fluid changed every two years. I don't track the car.
    Many thanks as always,
    Alan
    Alan
    N.J.
    1964 E-Type roadster
    1969 911S
    1988 328GTB
    2002 Maranello
    With that kind of maintenance you're probably okay.
