Results 1 to 1 of 1
Thread: FS: 1970 911t
    FS: 1970 911t
    SOLD!
    The engine is a 1969 911E engine that was rebuilt into a 69 911T engine case. All of the 911E parts are present. It has a ’69 MFI system, aluminum cylinders, 911E cams and pistons. The engine seems to run well but needs a cold start enrichment. It has the Carrera chain tensioner upgrade. I had a leakdown test done on (July 19, 2015) 5% - 7% on all cylinders except for #4 which was 12%. Compression shows 125psi on 5 cylinders and 120psi on the 6th.
    Details
    - Heat exchanger on MFI side needs to be replaced.
    - Suspension Pan needs to be replaced.
    - Exhaust is good
    - The interior has a decent dash. It has a couple of the usual cracks.
    - All of the floor pans have been replaced with new.
    - The rocker panels look like new replacements.
    - Lateral supports near the fuel tank have rust and need to be replaced
    - The rear bumper is from a newer 911. However, I have the matching bumper ends.
    - 1st and 2nd gears of transmission need to be rebuilt
    Price: SOLD
Tags for this Thread
