Results 1 to 10 of 11
Thread: Master cylinder warning light question
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    Attached is a photo of the MC on my '69 911S. As you can see, the brake fluid warning light switch has seen better days and is not connected to the two wires nearby. My questions are:
    - the switch has only one terminal but there are two wires. Can I assume that this is a replacement MC that came with a single terminal while the original factory MC had two terminals?
    - assuming two terminals are correct, does the switch connect the two wires together when there's a loss of brake fluid? Alternatively, does the switch connect the two wires to ground if there's a fluid loss?
    - if I try to replace the single-pole warning switch with one that has two terminals I assume I'd have to subsequently bleed the entire braking system to eliminate any air, correct?
    Any help is much appreciated, as always.
    Alan
    Alan
    N.J.
    1964 E-Type roadster
    1969 911S
    1988 328GTB
    2002 Maranello
    David Sperow Davz912/911's Avatar
    Sep 2006
    South San Francisco
    Alan,
    I want to say that's the "brake light" switch. A low fluid switch would be a float in the reservoir.
    Some switches are single pole, others two. My 67 tho has a switch above the brake pedal.
    just my 2c...I've been known to be wrong.
    Dave
    911S registry #1103
    R-Gruppe #513
    1967 912 converted to 2.2
    Period Dune Buggy
    Some drive Porsches' to be seen.....
    I prefer it when nobodys looking.
    Does your handbrake warning light work?
    Apr 2003
    New Jersey
    Yes, my handbrake warning light and brake lights all work.
    Alan
    N.J.
    1969 911S
    1988 328GTB
    2002 Maranello
    Then don'T worry about the wires, that is to tell you that you'be lost fluid in one circuit. You'll know when that happens.
    Oct 2010
    Southern Ca.
    Connect the brown wire with the white stripe to the terminal . The switch provides continuity to ground when fluid is low in either the font or rear lines creating an imbalance that moves a rod that triggers the switch . The e-brake light will now stay on . The switch has to be reset by pushing on the small white plastic rod in the center when this happens . Sometimes this happens when bleeding brakes .,
    Apr 2012
    Simi Valley Ca
    Original equipment was a switch with two spades. Replacement M/C comes with switch with one spade.
    Bob B
    Apr 2003
    New Jersey
    Bob:
    Yes...since I have two wires it seems logical that the original MC had two spades. So, does this mean that the switch would connect the two wires together when fluid was low?
    Alan
    N.J.
    1969 911S
    1988 328GTB
    2002 Maranello
    Apr 2012
    Simi Valley Ca
    lopena,
    See Richy's reply above. I looked at the schematic but couldn't figure out where the switch was, but I assume that one of those wires is ground, and the other goes to the light. Follow Richy's advice above and it should work.
    I assume that from the factory, the switch was provided with a ground wire, but later on the switch was grounded internally, so only the wire to the light is necessary.
    Bob B
    http://www.pelicanparts.com/911/911_...l_diagrams.htm
    Want to revive this thread.....
    Several questions ....
    My harness has 2 connectors and the MC has one spade with a small plunger .
    Why not replace the switch to a 2 spade ?
    There must have been a function for both spades?
    Not sure I understand the logic of forgetting about the other connector.
    Also What actuates the plunger
    Thanks for info
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
