I went to drive my 70 911 the other night and both the low and high beams were on. The dimmer switch had no effect on the lights. I took the dimmer switch out of the column and it appears that the switch operates correctly as the contacts open and close as they should. When using the lever pull back "flash" option with the headlight switch off both contacts energize, I don't know if that is how it is suppose to work. I removed the headlight flash relay and then I have low and high beams on with the dimmer switch in the low position and no lights in the high position. I am a little confused and any help will be appreciated.
Jule
