Results 1 to 7 of 7
Thread: Aluminum case engine question
    Seasoned Veteran
    Jan 2011
    Northern Ohio
    So back in the day (when aluminum cases were a dime a dozen) I used an aluminum case to build a 2.8
    engine due to the strength. 901 shop did it and it is/was a great engine. Case # for Reference is 907637 901/05 4502---late 65 I think.
    Question is I assume the spigots were bored to fit the 2.8 P&C's so is it possible for this engine block to
    be useful as a 2.0 block ever again?
    300359
    Banned
    Nov 2004
    Scottsdale, AZ
    Yes.
    EZ PZ.
    (Actually that would be a '66/'67 I believe.)
    Seasoned Veteran
    Jan 2011
    Northern Ohio
    Wow thanks for the quick reply Frank.
    Re: year I was looking at davep's 901 engine build # chart and it appears the engine was from 10-11/65, but probably came in a 66 car?
    300359
    Banned
    Nov 2004
    Scottsdale, AZ
    Yep. You're right. '66.
    PM sent.
    Sorry, how can 907637 come in a 65, my own 907316 rolled off on April 1, 1966. Or is it a specific out of sequence case that we have Kardex for?
    Seasoned Veteran
    Jan 2011
    Northern Ohio
    Sorry, was just looking at davep's chart shown here: http://www.early911sregistry.org/for...Engine-Build-s
    Name:  engine numbers.png
    and it looks like my engine was built between 9 and 11 of 1965, based on davep's chart.
    Probably came in a 66 car.
    300359
    I see what you are saying the casting date is 65 (so is mine)
