Thread: High Butterfly and Slide Valve Dimensions
    Apr 2013
    San Diego, CA
    I was wondering if someone could please help me with some very approximate dimensions of two early 911 intake systems: the "high-butterfly" and "slide-valve" setups. What I'm looking for is the approx. height of:
    i) the intake trumpet/stack
    ii) the intake runner containing the throttle valve/slide
    Also, if you happen to know the typical ID of the trumpets, that would be useful too.
    Here are some pics of the systems I'm referring to:
    Thanks!
    Ferrino,
    Give Matt a call, he should be able to help'ya
    http://www.eurometrix.ws/
    Cheers,
    Chuck
    Apr 2013
    San Diego, CA
    Thanks! Mark Jung kindly provided me with the following dimensions for the high-butterfly setup: The throttle Bodies are 152mm and the stacks are 145mm.
    Can anyone please help with the slide-valve setup?
