Thread: Koni Strut ID
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    Koni Strut ID
    I'm trying to identify if these are early or late type struts so I can buy the correct ball-joints and inserts.
    I assume that the 6 80 stamp below the part no is a date stamp in which case they are clearly late type struts?
    Cam
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
    May 2006
    Adelaide, Australia
    Anyone able to assist please!?
    '74 RS 3.0 Replica
    Port Macquarie, Australia
    Pretty sure that's a wedge bolt set up (later). My 69 struts use a 'clamping' set up...
    John Forcier
    EarlyS #1987
    Restoration Saga
    It's the wedge type as John said, the clamp type strut would have a slot cut at the bottom.
    May 2006
    Adelaide, Australia
    Thanks Gentlemen
    '74 RS 3.0 Replica
