Thread: FS: 1970 911T Hot Rod
    Junior Member
    Jul 2013
    Androscoggin Maine
    Well here goes! I bought this 911 a couple of years ago and have been going through it since this March. When the 1974 Carrera spec 2.7 was rebuilt it had Weber 40IDA's and oil cooler installed and runs very strong. Rebuild was done at 44700 mi. odometer now shows 60700 mi. It was also given an upgraded suspension. It has a 901 5 speed transmission and shifts fine with no unusual noises. The underside is very solid and has new stainless heat exchangers. Work I plan to do in the near future involves a bump steer kit, as with the lowering this should have been done, as well as an alignment. Suspension bushings are on the horizon. Sunroof motor is a bit sluggish and needs a look, though it works. It smokes a bit on initial startup but clears quickly and burns very little oil. Compression is good. Fast and fun!
    I'm asking $55,000.
    IMG_2546.jpgIMG_2471.jpgIMG_2522.jpgIMG_2543.jpgIMG_2554.jpgIMG_2555.jpgIMG_2565.jpgImage.jpgIMG_2501.JPGIMG_2498.jpg
    Jun 2011
    Bedford NY
    What is the story with that paint?
    Is it a wrap that can come off?
    What is condition of dash?
    Can you describe the car in better detail?
    Junior Member
    Jul 2013
    Androscoggin Maine
    Sold! Sold!
