Results 1 to 10 of 11
Thread: 1973 911T MFI fuel hose size help
    Mar 2015
    Orange Ca
    I'm replacing all the rubber fuel hoses on my 1973 911t mfi before I get it back on the road, I'm starting at the ones that connect to the gas tank, I need Help I don't know the sizes and I don't know which ones to order on pelican the sizes they have got me mixed up and how much I'm going to need for the car front(gas tank )and back(engine), also do I have to replace the lines that are under the pan?
    Thank so much this is my first 911
    Also any recommendations on what clamps to use?
    The suction hose is 9mm I.D. the pressure hose is 7.00 mm I.D. (although We use 7.5, either will work) The line thru the tunnel is metal, other than that replace all of it. Measure line length and get more than you think you'll need.
    Oct 2004
    SW Suburbs of Chicago
    Not to hijack but to enhance... when replacing the lines from the tunnel to the fuel pump (stock '72 location) it looks very tight where the lines meet the body. I assume the sway bar and trans mount must be dropped. Are there any tips to this or is it pretty straight forward once those items are out of the way?
    Mike O'Meara
    Reg #1043
    72 911T
    56,59 356s gone
    67,68 912s gone
    Mar 2015
    Orange Ca
    Thanks for your help, it's just that on pelican has the sizes listed like this
    "Fuel Hose - 5.5 X 10.5 mm - Outside Cloth Braided" how do I know the size for 7.000mm & 9.00mm I.D?
    Also working pressure means that it's okay to use with fuel injection pressure?
    I have no clue as to how Pelican sizes their hose, we don'T buy from them. We buy from Wurth.
    Yes, you'll need to remove Trans cross member to access hoses.
    Are the sizes for the E and S MFI cars the same?
    Rusty
    Yep, sure are.
    Mar 2015
    Orange Ca
    I'm new to the site, wurth is a member here?
    Wurth is an OEM supplier to most German Auto factories.
    http://www.wurthusa.com/web/en/website/index.php
    Mar 2015
    Orange Ca
    thanks so much for your help, going to place my order today. wurth doesn't have a 9mm id fuel injection hose.
    did you buy it from another place?
    yhanks for your help just don't want to buy the wrong stuff
