Results 1 to 7 of 7
Thread: FS: Parting out 3.0L
    Oct 2004
    Cambridge, MA
    From an 80, will take it apart on Sunday. All parts + shipping. Some of these parts I have to confirm specs and quality, but it was a good running motor before being pulled and put into storage.
    More pics below. Crank, pistons, cylinders, heads are all excellent, so this was a good motor before I tore it apart.
    Red shroud $150
    Wiring harness $150
    Fan shroud strap $50
    Engine cradle $85
    Sheet metal set (also have front tray) $250
    Upper valve covers $100 SOLD
    Lower Turbo valve covers $150
    Rockers $225
    Chain box covers $100 SOLD
    Chain boxes $150
    Cam towers $150 SOLD
    Heads $600
    P/C, Alusil, excellent, can send hi-res pics $600
    Rods $600
    Crank (STD/STD) $1,200 (pending)
    Case $1,000
    Engine tin $100 SOLD
    Oil cooler $250
    Breather $45
    Tru6 Restoration & Design
    69S Targa, Velvet Green
    73T Coupe, Gemini Blue
    Early S Registry #1462
    Oct 2004
    Cambridge, MA
    Pic of the engine sheetmetal. Note the rust on the front tray. Nothing serious but some pitting will be there when cleaned up.
    Oct 2004
    Cambridge, MA
    Chain boxes, very nice.
    oil cooler, nice shape
    Oil pump? No?
    Mar 2004
    Castro Valley, Ca.
    wide idler arms ?
    hi Shaun
    1940 Mercury town sedan
    Oct 2004
    Cambridge, MA
    Hi Rick, I'm parting out another 3.0 long block and that should have a good pump in it.
    Hi Jerry, I'll check later today and let you know.
    Mar 2004
    Castro Valley, Ca.
    hi Shaun;
    any luck on the wide idlers ?
    thanks
    jerry
