Results 1 to 1 of 1
Thread: Early Door Hinge Question
    Senior Member 302340's Avatar
    Feb 2008
    Milwaukee, WI, USA
    Hello everyone,
    I have two pairs of early door hinges. Both of these pairs should be for hex bolt use (no recess for triple-square bolts). However, one pair has larger bolt hole sizes, approximately 11.5 mm, and the smaller holes of the other pair measure 10 mm. The hinges with the larger holes also have a "triangled 49" stamped into them. In the attached picture, I show one hinge from each of the pairs. When mounting the doors, will there be a difference between the pairs? And, does anyone know the manufactured years of these two pairs?
    Thanks!
    Lee
    302340
    Member #1277
