Results 1 to 7 of 7
Thread: FS: 1970 911 T Karman Coupe
    Vin# 9110122227
    Eng# 6107244 911/07
    Trans# 7105438 911 01
    Originally a Signal Orange car paint code 1414. Now painted white. No COA I called Porsche of North America they confirmed the engine is original to the car, I didn't ask about the trans number. 918XX miles thought to be original by previous owner. Some rust in rockers and small hole in passenger side rocker, kidney boxes are rusty, and a little surface rust under car.
    Engine was rebuilt to stock specs approximately 3000 miles ago when car was owned by an Early 911S registry member. Heat exchangers were replaced with factory Porsche exchangers the Porsche part# stickers are still on them. Carbs are rebuilt Zeniths. Trans had worn 2-3 shift sleeve and worn synchro bands replaced 500 miles ago.
    Parts replaced in last 1500 miles:
    Tires Bridgestone Potenza Pole Position 195 65 15
    Shocks Bilstein HD front and rear
    Restored and plated calipers front and rear
    Brake pads
    Front and rear wheel bearings
    Spring plate bushings
    Shift rod and coupler bushings
    Throttle linkage bushings
    Wheels are 15x6 Fuchs with 1974 dates
    Spare is 14x5.5 with old tire. No jack or tool kit
    Gas tank cleaned and sealed with KBS kit. Exterior stripped, primed, Upol gravatex coated, and painted.
    Fuel lines replaced
    Carpet replaced by previous owner, new coco mats
    Original seats (a little soft), sidewall panels, headliner, map pockets are a little tired.
    Dash has a crack from clock to the corner of the speaker.
    Speaker cover has a little wave to it.
    Original seat belts, missing a few plastic pieces.
    Gauges are very nice, clock runs a little slow.
    Owners manual, no tool kit or jack.
    Car is a good driver, gets plenty of attention, and could be driven as is for years.
    I was going to fix the rust and return it to signal orange but plans have changed.
    Car is located in Park City Utah
    Price $42,250
    Registry #2507
    1970 911T
    PM sent...
    Pending to Erick
    Registry #2507
    1970 911T
    Eight hours, thirty-five minutes . . .
    . . . and thank you for posting your car here!
    Looks like a Real Little Sweetie
    Sold
    Thanks Early 911S Registry
    Registry #2507
    1970 911T
