Results 1 to 1 of 1
Thread: FS: Modified 3.0 turbo intake manifold
    Selling a modified 3.0 turbo intake manifold from a '76 930. The intake ports were opened up to 40mm by Turbo Kraft to match their aluminum injector blocks. I tapped for 2 sensors, the rear hole below the csv is tapped for m8x1.25 (this was the MAP outlet), the top hole is tapped for m10x1.0 (I mounted the AEM boost sensor here) The 3.0 throttle body is stock. Painted silver using VHT high temp engine paint. Has about 2 hrs. of run time since the mods. I'm switching to a 3.3 manifold to use a i/c. $400.00/b/o includes ConUS shipping. Contact: harold@dino.com
    Harold
    All gone:
    '73S coupe
    '73E targa (RGruppe)
    '73T targa
    '72E targa
    '79 930/DP935
    '68 VW Crewcab 3.3 930 turbo bus
    '86 VW Doka
    DP935 Registry
